This time we will be doing something different for Weekly Challenge. Basically, you will choose a mix of a color (Red / Green / Blue), object (Vehicle / Food / Plant), and location (Moon / Arctic / Desert) from provided choices then make a render based on the selected mix.
For example : someone picks red + food + desert, then made a render of a strawberry icecream in an oasis/desert. As you can see, you can tweak the color/object/location a bit (in this example, desert and oasis are still closely related).
You are free to choose whichever you’d like, just pick one from each color/object/location. However, if you want you can also use the assignments provided below based on your name and date & month of birth :
First name initial : (Main) Color
A-H : red
I-P : green
Q-Z : blue
Date of Birth : Object Type
1-10 : vehicle
11-20 : food
21-31 : plant
Again, you do NOT have to use the above assignments, you can just freely choose one from each category as you like. In your submission, please mention the options that you choose or get (e.g. “blue + plant + beach”).
Hope you will enjoy it, looking forward to seeing your creative renders !
