Having a go at making a shed - here are some progress pics. Have a question (re texture the panels - is there a way to randomise the texture ? or do i need to apply a slightly altered texture to each panel? (FYI each panel are separate objects). Cheers
Sorry I didn’t catch this when I was just on. Seen it when I was signing out. Yes there is a way, there is an object info node and it carries a random output connection. Here is a quick screenshot of the node group that is used to create the randomness.
First image is the settings for the standard texture setups other than having the textures set to box, and the Input/texture coordinate node set to object.
Second image is a grouped view of the randomized portion. Object info node is located in the Input portion of the node addition, all the rest are in the converter portion of the node addition.
Sorry, forgot to show the result of that node setup. Here you go. It is all just one cube then made an instance for the other three. Each time you create a new instance the texture will be different.
There are several good ways to randomize the textures. The one Steve list is a great way. Input nodes like object info are great to use with noise textures also to add grunge and chipped paint and such. Looking really good BTW.
Thank you so much Steve (@flyingbanana) - your guidance was perfect - great tip to remember for future projects too. Much appreciated for your help. Cheers
Got home and went into my shed and noticed a few spare fly screens just sittin there - thought ‘why put fly screens up in a shed??’ so i decided not to for this project - best to have them stored in the shed. BTW - Thank you Alex for your alpha tip - it worked really well and has improved the render.
