hi, i have in this file a diamond.obj i found online and want it to behave the same way the diamond from the jewellerycraft addon behaves.
untitled.blend (42.9 MB)
Hey Kastrioti. Welcome my friend. So what are you trying to do exactly? Also if you want a diamond, you can enable the “Extra Objects” addon in the preferences & then hit SHIFT+A and Mesh & go to diamonds and add a diamond that way
thanks i didnt know i could add diamonds like that, ok so heres another video using prongs as an example, the prongs i spawn in with the jewellcraft behave correctley, they go inside the shape and allow me to move them around but when i import by own prong object it doesnt move around correctly it should be moving in a horizontal way not a verticle way ( ignore the background noise, im watching a series :P)
You probably just need to add a solidify modifier for it to have refraction from the walls of t the diamond
but taking that off doesnt then attach onto the other object, it moves freely, i want it to attach onto it just like how the prong was doing in the video
I don’t believe you can make it act like the addon, that was probably coded into the addon, thats a feature of the addon. you will have to place it manually, or stick to only what the addon can do. Addons are coded usually to make lots of steps into a simple task. You will probably have to learn to adapt to the limitations
